how to diconnect fuel lines?
Old Aug 1, 2004 | 12:16 PM
94Zpower's Avatar
I trying to swap my fuel press reg and can't figure out how disconnect the fuel lines from the regulator can any one help me out on how to do this.
and btw: what size torx bit do I need to get the fpr off of the fuel rail?
Thanks!
Old Aug 1, 2004 | 12:18 PM
Kryckter's Avatar
Re: how to diconnect fuel lines?
Dont know about the torx bit size but I do know that there is a tool that you buy to disconnect the fuel lines. There is several types of tools but it is a circle piece that slides into the fitting, You then push the line on further, And then pull off. All auto parts stores sell this tool, Simply called a fuel line disconnect tool.
Old Aug 1, 2004 | 12:51 PM
94Zpower's Avatar
I'm gonna go pick one up thanks!
Old Aug 1, 2004 | 01:19 PM
ibanez6rg's Avatar
The fuel lines are two different sizes, so make sure you get the tool with both sizes on it.
Old Aug 1, 2004 | 02:08 PM
5/16 and 3/8
Old Aug 1, 2004 | 02:51 PM
94Zpower's Avatar
anyone know about the Torx bit size?? I am using a T-27 and it seemes to sliping and the only other size I can find is a T-30 and its too big!
Old Aug 2, 2004 | 11:49 AM
The Torx screw on the FPR is a T27. And, there is no need to disconnect the fuel lines. You release the clip the holds the 2 hard lines to the intake manifold bracket, and pull the spring clip off the regulator, and the line pulls out of the regulator. Much easier that way, IMHO.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
