how to delete codes in the pcm
Old Sep 20, 2003 | 11:43 PM
JohnsSS's Avatar
My SES light keeps coming on when the engine fan comes on beacuse i removed the secondary air system, the air pump.
I just want to delete the code that way the SES light goes away, how can this be done?
Old Sep 20, 2003 | 11:46 PM
madwolf's Avatar
It can be done through reprogramming.
It also can be done by placing the right resistor value in the connector, but unfortunately, I don't know what is it... Maybe someone else knows and will reply...
Old Sep 20, 2003 | 11:54 PM
JohnsSS's Avatar
^^^ this would be good...if anyone know's what the correct resistor is, that would be nice. Where can you get resistors? ACE, Advanced, A-Zone, Napa?
Old Sep 20, 2003 | 11:56 PM
madwolf's Avatar
Radioshack.
Old Sep 21, 2003 | 04:18 PM
JohnsSS's Avatar
radio shack, now what resistor size/value is needed for that air pump plug???
Old Sep 22, 2003 | 05:15 PM
JohnsSS's Avatar
stilll looking for the resistor value of the air pump sensor
ttt
Old Sep 22, 2003 | 05:20 PM
Lyle A's Avatar
If you still have the air pump relay, read the coil with an Ohm meter and just match that resistance. My guess is a 2.2 Kohm might work. You could but an assortment package and just go trial and error.
Old Sep 22, 2003 | 05:42 PM
JohnsSS's Avatar
k thanks
DirtyDaveW
Dec 1, 2016 05:37 PM
alex5366
Mar 8, 2015 11:32 AM
armedtrigger
Feb 24, 2015 08:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
91Bird305
Aug 5, 2002 01:39 PM
