How crucial is it to fix an oil sensor leak?
Old Jun 8, 2008 | 05:56 PM
lt1stroker's Avatar
I was wondering how crucial is to fix an oil sensor leak?
Old Jun 8, 2008 | 06:17 PM
windsma's Avatar
oil pressure sensor or oil level?
Oil pressure is super easy to get to, just put some thread tape on it.
Old Jun 8, 2008 | 06:53 PM
When you run out of oil from the leak, it will be more than crucial.
Old Jun 8, 2008 | 07:01 PM
Counted Out's Avatar
Mine was leaking pretty bad once, it doesn't cost much to fix.
Old Jun 8, 2008 | 08:10 PM
OBE1 95Z28's Avatar
1993 oil pressure sensor has easy access; the 1996 is located differently (behind the intake manifold below the EGR valve) and a little tricker to get to; Shoebox has a photo here: http://shbox.com/1/op_sensor.jpg
Old Jun 8, 2008 | 08:13 PM
windsma's Avatar
yeah my 93 was easy, but had a replacement engine from a 97, It was a little harder.
Old Jun 8, 2008 | 09:08 PM
lt1stroker's Avatar
could the oil leak cause smoke to come out of the engine hood and the car too die?
Old Jun 8, 2008 | 09:13 PM
If the oil is dripping on hot exhaust components, its going to burn and smoke. Probably won't cause the engine to stall. But its going to reduce the accuracy of the oil pressure sensor.
How did you determine it was leaking? How badly is it leaking? How much oil is the engine using?
Old Jun 8, 2008 | 09:21 PM
lt1stroker's Avatar
When i first bought the car the oil was leaking from the intake gasket. he changed it for me and everything. then when i took it to my mechanic to for a pre buy inspection he told me i need to fix the oil sensor. so i thought no big deal. then after i took the car out for about 25 miles, all hell broke loose. The rear of the car started to make popping and grinding noises and when i got home the car stalled(has nothing to do with my previous post about stalling, had the idle adjusted) and smoke started to come from my hood. I checked under the car and oil was dripping. now about i say a quarter of a quart is gone. i dont know how much oil the car has been using. Where should my oil gauge be when driving?
Old Jun 8, 2008 | 10:36 PM
Jazsun's Avatar
You don't have an oil gauge only an oil pressure gauge. It should be around at leaste 20 at idle and 30ish when driving normal. 40+ at WOT
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
MislMan
Jul 19, 2002 11:41 AM
