How to change an opti
Old Feb 3, 2009 | 07:47 PM
cboggs5's Avatar
Ill will be changing an opti in the morning and I would like any info to make it go smoothly. Its a 93 Z28 with a new coil. Please and info will b great. If anyone has a site on how to remove and replace it properly will also be great. Thanks
Old Feb 3, 2009 | 08:17 PM
RamAir95TA's Avatar
It's fairly straight-forward.
Drain coolant (petcock valve on the radiator).
Remove belt (release tensioner).
Remove crank pulley (might need a 3-toe puller if yours has never been off).
Remove hoses from water pump.
Remove water pump.
Remove 3 optispark mounting bolts and wires, and remove.
Reinstall new opti/wires.
Reinstall water pump and hoses.
Fill radiator back up and bleed the system.
That's the short version. You might want to get a Chiltons or Haynes manual for the hell of it though.
Old Feb 3, 2009 | 09:33 PM
cnorton's Avatar
Shoebox.com is worth reading:
http://shbox.com/1/how_tos.html
Specific instructions on each of the steps mentioned above can be found on Shoe's site.
Old Feb 3, 2009 | 09:52 PM
Here is another write-up:
http://www.lt1engine.com/tech/93-97-...emove-replace/
Old Feb 3, 2009 | 10:41 PM
95Blackhawk's Avatar
You MUST have the right tools for the dampener hub. Get those first.
Old Feb 4, 2009 | 03:53 AM
MikeGyver's Avatar
I would NEVER recommend you -try- to remove that damn ballancer hub!
As I recall, I simply removed the harmonic ballancer and left the hub on the crank and had no problems working around it.
Don't forget to loctite the hell out of the screws that hold the rotor down as they often loosen up and kill opti's.
Old Feb 4, 2009 | 04:51 AM
sbs's Avatar
sbs
You don't remove the hub to replace the opti.
Old Feb 4, 2009 | 06:41 AM
cboggs5's Avatar
Thanks guys. Ill let you all knw how it goes. I'm about to get started. So do I or don't I need to remove the harmonic balancer
Old Feb 4, 2009 | 06:53 AM
You remove the pulley/damper, not the hub.
Old Feb 4, 2009 | 09:21 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If you like working on stuff, it will be fun.
Old Feb 4, 2009 | 04:58 PM
cboggs5's Avatar
Thanks to all the advice the removal went very smoothly, but while under the car I think I see the culprit of the opti failure. The cap and plug wires were covered with oil and I noticed a small leak under the timing cover. Is there someone that can help with my next steps. My dad thinks I should remove the hub and timing cover to fix. I thought I would get some opinions before I proceed.
Old Feb 4, 2009 | 05:15 PM
cboggs5's Avatar
To be a little more specific the leak is coming from the bottom of the crank pan seal jus below the timing cover
Old Feb 4, 2009 | 07:21 PM
BTC's Avatar
BTC
It's very common for both the water pump driveshaft seal and opti seal, in the timing cover, to leak. I replaced both of those seals when I replaced my opti. It will probably be hard to verify exactly where the leak is coming from without the engine running, but I would recommend replacing both of those seals. I didn't the first time around, and my water pump seal was leaking like a sieve, and I had to do everything again. Do a search on replacing those seals. Unless there is something different about the 93's, the timing cover doesn't have to be removed to replace those seals. If those seals are leaking, it could appear that the crank seal is leaking just because the oil would run to the bottom of the engine. I did not have to replace my crank seal, and my car has just over 100K.
I would do the above before proceeding with replacing the crank seal. I've never replaced one of those seals, but I would want to be absolutely sure it's leaking before doing so.
Old Feb 5, 2009 | 10:11 AM
cboggs5's Avatar
it seem that the harmonic balancer is bad( excessive wear to the belt) and it blew the seal. thats where the oil is coming from. can anyone help me with replacing the crank seal on the timing cover
Old Feb 5, 2009 | 01:32 PM
https://www.camaroz28.com/forums/sho...d.php?t=526266
