How can I safely cut down an ARP main bolt?
Old Feb 16, 2007 | 07:26 PM
wrd1972's Avatar
How can I safely cut down an ARP main stud?
I need to cut down the length of an ARP main stud, it is a long windage tray bolt but it is on the #5 and not being used with the windage tray. It is rubbing the Melling select oil pump. If I cut the smaller theaded extension off then the clearance will be better. I am not talking about the larger threaded area used to secure the main.
I want to make sure that I dont compromise the strength of the bolt while doing this. I am thinking using a thin cut-off wheel in a grinder.
Any advice?
Old Feb 16, 2007 | 08:42 PM
Boosted_Z28's Avatar
A thin abrasive wheel in an air die grinder or high speed electric grinder has always worked well for me...little to no heat is generated this way.
Old Feb 16, 2007 | 09:01 PM
12SCNDZ's Avatar
I used a hacksaw.
Frank
Old Feb 16, 2007 | 10:01 PM
Originally Posted by 12SCNDZ
I used a hacksaw.
Frank
Nothing wrong with old school.
Old Feb 17, 2007 | 07:26 AM
wrd1972's Avatar
I used a hacksaw.
Frank
Well duh.
I guess its easy to get warapped up in technology and forget about the fundamentals. Now if I can just find my hacksaw.
Thanks guys.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
