Clearancing block for 383
Old Feb 16, 2007 | 03:47 PM
Demus's Avatar
How difficult is it to clearance a block for a 383 stroker rebuild?
I've decided I'm at the very least doing a 355 rebuild, with new bearings, pistons, rods, and probably a crank. I figure, midaswell do a 383, but I'm not sure about clearancing the block myself.
Old Feb 16, 2007 | 03:53 PM
rskrause's Avatar
Moderator
It's not hard, but the block has to go to the machine shop anyway. I'd have them do it.
Rich
Old Feb 16, 2007 | 09:53 PM
95Blackhawk's Avatar
On my bill it was a $75 charge. Go get it done.
Old Feb 17, 2007 | 05:53 AM
94zgreenmachine's Avatar
Watch your oil pan as well. I had a very small area that rubbed ever so slighty. A little tap from the ball peen hammer(It did not take much at all) and it rubbed no more. No leaks either.Like I said, hit it ever so slighty and continue to test fit it. Better to go small than way too much.
Old Feb 17, 2007 | 06:26 AM
rskrause's Avatar
Moderator
BTW: I can understand the DIY mentality. I have lots of things, once, to prove I could do it, learn something, etc. So if you want to DIY, I understand. In that case, a tip. Grinding cast iron require a good die grinder. The pneumatic types are far superior to the electric models - they are lighter, smaller, and more powerful.
Rich
Old Feb 17, 2007 | 08:36 AM
mdacton's Avatar
also take your time... and be very careful
I know somebody.....won't mention there name that poked a whole in a block
Drtryder
Apr 22, 2015 04:17 PM
carl.froehlich
Mar 13, 2015 12:38 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
TAChad
Jun 14, 2002 03:44 PM
