How about my cam?
Old Oct 27, 2011 | 09:48 PM
raroz28's Avatar
How about my cam?
Piggy backing off the other cam thread.
What can you guys tell me about my cam based on the specs?
226/231 .560/.569 114 LSA 1.6RR.
Cam feels strong and runs hard to 6800 RPM but I had a noticeable loss compared to the throttle response and torque of the stock cam.
Old Oct 28, 2011 | 12:16 PM
Mystery Bird's Avatar
Re: How about my cam?
Looks like a pretty good cam for the street and occasional strip. Did you get it tuned after the install? My throttle response got better than stock cam and it's a bit bigger than yours.
Old Oct 28, 2011 | 02:53 PM
vangill's Avatar
i had a 224 236 dur cam and lost quite a bit of off the line torque it felt like. i ended up going to something smaller since my cars 100% street duty
Old Oct 28, 2011 | 06:09 PM
Bersaglieri's Avatar
Got some valve event specs or anything else? Post up what you've got on the cam card. Who ground it?
-Dustin-
Old Oct 28, 2011 | 07:55 PM
raroz28's Avatar
-Dustin-
NuTek custom grind.
Old Oct 28, 2011 | 08:55 PM
96capricemgr's Avatar
What gears do you have?
A 114 LSA is usually for emissions or boost but I didn't think that was a concern in Detroit.
For a non-emissions NA car I wouldn't run one that wide, but if it is in the car and you like the power don't overthink it.
A M6 car should have at least 3.73s if not 4.10s the double overdrive soaks it up and it will help lowend a LOT.
Old Oct 30, 2011 | 06:26 PM
raroz28's Avatar
Stock gear. Emissions isn't a concern but I wanted the 114 for the smoothness.
I am going to buy a 4.10 gear in the next week and have it installed while it's in storage.
So once I put in the bigger gear it will probably wake it up a lot and maximize the cam? I ordered a new set of headers which should be here tomorrow so that should free up some of the blockage I'm getting from the crappy Y pipe that's on my car now.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
