HOT Cam, what springs/rockers
Old Dec 28, 2008 | 02:11 AM
  #16
WS6T3RROR's Avatar
NO proform rockers!
Look into scorpions if you want to go cheap, I have used a bunch of them with no trouble.
Those springs will handle that cam and much much more. I have been very satisfied with them and been up to 7k with them several times with wilder cams.
You're going to have trouble finding self aligning rockers that fit 7/16" studs because the larger stud rockers take up more room in the valve covers and are more of a challenge to fit in centerbolt valve covers. Not too much issue though plenty have fit em under there.
Old Dec 28, 2008 | 06:48 PM
  #17
JMG97SS's Avatar
Originally Posted by WS6T3RROR
NO proform rockers!
The stock shafts not 7/16 is it?
Old Dec 28, 2008 | 07:04 PM
  #18
6SpdLT1Z's Avatar
I have a set of proform rockers FS if your interested. Brand new, never been installed.
Old Dec 28, 2008 | 08:54 PM
  #19
WS6T3RROR's Avatar
Stock studs are 3/8" at the top where the rocker rides and the poly-loc goes on. The part of the stud that screws into the head is 7/16" either way. If you want to use the stock studs you need 3/8" rockers.
Old Dec 28, 2008 | 09:42 PM
  #20
JMG97SS's Avatar
After doing a search on Proform and reading I believe Ill pass. Im guess Im going Summit or Scorpion
Old Dec 30, 2008 | 11:12 PM
  #21
Ultra_Dog's Avatar
DO NOT USE ANYTHING OTHER THAN GMPP SPRINGS.
I didn't listen to my own advice, but took the advice of a mechanic who was wrong...FOUR TIMES!!!
DO NOT USE MANLY SPRINGS. I RECOMMEND THE SPRINGS THAT COME IN THE KIT.
Been there, done that, made mistakes, offering free advice. Take it or leave it.
Old Dec 31, 2008 | 12:01 AM
  #22
6SpdLT1Z's Avatar
Originally Posted by Z-RATED94
I believe the LT4 had lighter valves than the LT1s. I could be wrong about that, but it doesn't hurt to use a spring with a little more pressure than required for a given cam.
The LT4 Spring accommodates for more lift than the hotcam w/ 1.6rr's. Thousands of people have used them and I haven't personally heard anyone having LT4 Springs fail (though there maybe a few, but I'd have to search for it and know more about there setup to even know if it was the springs fault)
Old Dec 31, 2008 | 04:06 AM
  #23
WS6T3RROR's Avatar
I'm not a fan of the lt4 springs but they will work. They will be pretty much maxed out with the hotcam but they will handle it fine. I would not dare use them with anymore lift than the hotcam has, they are close enough to coil bind for my taste with that even. The open pressure is just fine on them but the 100# seated pressure leaves something to be desired imo. Also be aware, stated rocker ratio is not always what you get and will changed based on geometry and rocker brand.
Old Dec 31, 2008 | 05:16 AM
  #24
JMG97SS's Avatar
I dont see how having a little better spring could hurt anything
Old Dec 31, 2008 | 07:18 AM
  #25
Z-RATED94's Avatar
Far more lift than the Hotcam? Where are you getting your info from? One last question, why NOT use a better spring?
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
