HOT Cam, what springs/rockers
Old Dec 25, 2008 | 08:47 PM
JMG97SS's Avatar
I just got a hot cam gave to me but its not the complete kit but its just the cam. What would be a good set of springs and rockers got go along with it?
Old Dec 25, 2008 | 09:15 PM
6SpdLT1Z's Avatar
Comp Pro Mags or GMPP, IMO.
Old Dec 25, 2008 | 10:24 PM
Bersaglieri's Avatar
If is isnt going to a wild setup in the end, just some LT4 springs and aluminum roller rockers self aligning. Proform or Summit or something if your on a budget. I like Comp Cam Pro Mags and some nice crane springs, but it's all up to what you want.
-Dustin-
Old Dec 26, 2008 | 09:35 AM
JMG97SS's Avatar
Thanks guys, its not going to be to wild for now. This is my daily car and until I get something else its just mild. Can you buy the lt4 springs seperate? Where from?
Old Dec 26, 2008 | 09:41 AM
bubba4's Avatar
I bought LT4 springs, locks, and retainers in a kit from GM dealer for under $75.00 Prices vary from dealer to dealer. Good Luck
Old Dec 26, 2008 | 11:19 AM
n2ceptor's Avatar
www.sdpc2000.com
Old Dec 26, 2008 | 02:24 PM
2xr95z28's Avatar
I have a set of lt4 springs with the locks retainter and seats ill do 50 shipped for... I'll pm you
Old Dec 26, 2008 | 05:40 PM
Z-RATED94's Avatar
Do yourself a favor, spend a little more and buy some better springs.
Old Dec 27, 2008 | 12:39 AM
6SpdLT1Z's Avatar
LT4 Springs are fine for the hotcam. Money should be spent elsewhere. (Better rockers, replacing the timing chain, etc.)
Old Dec 27, 2008 | 12:47 AM
93FIRETURD's Avatar
Also the hot cam makes good power and is very reliable with 1.6 ratio rocker arms the stock arms are only 1.5 look into summit brand rockers if i am not mistaken Crane makes them but just doesn't put their name on them supposedly a very good set for the price
I am using the GMPP LT4 springs for my hot cam application and they are plenty of spring with this cam those will do the job you need done quite well
Old Dec 27, 2008 | 12:42 PM
Z-RATED94's Avatar
I believe the LT4 had lighter valves than the LT1s. I could be wrong about that, but it doesn't hurt to use a spring with a little more pressure than required for a given cam.
Old Dec 27, 2008 | 03:54 PM
Stl94LT1's Avatar
I would also use a better than LT4 spring.
Old Dec 27, 2008 | 09:29 PM
JMG97SS's Avatar
do I need to buy studs for the Summit or Proform rockers or stock ok? What about guide plates?
Old Dec 27, 2008 | 10:31 PM
You can buy 3/8" rockers that fit on stock studs or go bigger to 7/16". You buy the rockers to fit the size studs you want to use. No guideplates are needed with self aligning rockers, but with non self aligning ones you will. On mild setups like a hotcam 3/8" self aligning rockers should be fine.
-Dustin-
Old Dec 27, 2008 | 11:04 PM
JMG97SS's Avatar
Im looking at the Crane 10308-1 kit for the springs and maybe these Proform rockers http://store.summitracing.com/partde...5&autoview=sku , what do you guys think??
