Hot cam questions?
Originally posted by djgerry
Thanks for the replys everyone.
So i'll neeed a tune & a LT4 knock mod after the cam install?
What will that run me?
"Izod" buy more aggressive what did you have in mind?
I always like to put in my .02 re cam size, so...
There are cams even smaller than the Hot Cam that can put you in the low 12s and even into the 11s.
You might see higher RWHP from larger cams, but at what RPM?
It's not so much the size of the cam as how things work together and whether or not you care if the thing is a daily driver.
As far as dragging, no matter what cam you have, if you can't hook, you can't book.
With a small cam with tons of low-end and a good hook, you might even best a big cam by the traps, even if your MPH is slower.JMHO
well the key to sucess at the track, etc, is just what you said - making sure everything works together perfectly. planning your mods (esp. when going internal) will make your life much easier, and put together a faster car. good pnt. bubba (too often forgotten).
Yes it does matter the way things work together. If you have a headers and everything already the stuff should work fine along with some proper tuning. You wouldnt wanna put a big cam or even the hot cam on a car with stock manifolds. That doesnt work good together.
Yes you need some good sticky tires to hook. I couldnt agree more. But if you are gonna pay that amount of money for the hot cam kit and in a month later wish you went bigger why not save a $100 more and go with a little more aggressive cam. Just because you go one step bigger and get better rr's and springs doesnt mean the car cant be streetable. Just my .02
Bubba,
Very valid points but it's not easy getting a good hook when your 7.5" Rear end is paper thin. I personally prefer to lose the race by a Few tenths and trap 4-5 mph higher then win a race with a lower trap but that's just me. My car would still be the faster car.. he just hooked up better.
Originally posted by Sparkz28
The hotcam kit comes with crane roller rockers..... FYI
Thanks.
In a nutshell im looking for more power spread even across the whole RPM range, for my daily driver.
I dont plan on doing a cam untill i get headers & exhaust, the hot cam just sounded like a nice beginer cam for a mild daily driver.
Originally posted by drewstealth
Is there a 224/230 and a xe224/230? Or is it the same came?
My Hotcam has a damn nice lope to it. Not sure what some of you guys have heard. As far as the springs that come with it, i've heard the rumors too, but i've turned over 6000rpm with no problems. I am running the LT4 ED timing chain too.
