Hot Cam Kit........Do I need Stall?
Old Apr 19, 2005 | 05:36 PM
RobsZ's Avatar
I have my Hot Cam Kit ready to go in, and PCM 4 Less will be doing the programming. Will the stock stall be OK? Any drawbacks?
Thanks for your help.
Old Apr 19, 2005 | 05:53 PM
Ricardo's Avatar
Re: Hot Cam Kit........Do I need Stall?
The idle speed will be around 800 RPM for the hot cam. You can use your stock stall but your car will want to crawl at the stoplights.
A higher stall will also help you get in the powerband righ away. A 2400 stall does a nice job on a hotcammed LT1.
Old Apr 19, 2005 | 07:22 PM
jkipp84's Avatar
I agree. But I used my car as a daily driver/fun car, no real drag racing. The 2400 stall I had worked nicely with the XE 224/230 I had with an 850 idle. Solved the creeping when at a stop, helped a little with utilizing the power range of the cam a little better too.
If you do drag race, don't screw around with the big heavy (and hot running) 2400 stall. Get a real 9" 3000.
As always, with either stall (or even if you keep your stocker), install a trans cooler with that cam. Super cheap insurance.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 21, 2002 03:55 AM
Smokn '94 Z
Jul 28, 2002 02:38 AM
