Just got back from RT. 66
Old Aug 20, 2002 | 10:37 PM
Smokn '94 Z's Avatar
Smile Just got back from RT. 66
Well I did a little better than my previous best in the SIG. 12.91 on 1.81 60'. On my last run of 3 runs when it was really cool out I finally lost traction on my street tires. 2.12 60' & still ran a 13.2 I really think if I could have pulled another 1.81 60' I would have been in the 12.8 to 12.7 range. I lit them up. I knew eventually my luck would end with street tires. I really think with some Nittos or ET Streets that I have a legit 12.8 car. Can't wait to get a stall.
Teal '94 Z Beefed up A4, , 3.73 Motive & Eaton Posi. ----------- Hot Cam Kit, FLP's, A.I.R., EGR, TB Bypass, TPI's Aluminum Driveshaft, 52mm TB, Corsa, DMS springs, & PCM for less. New best on BFG Comp Ta's 17" tires.. New best 7/30/02 12.96 @106.55 1.82 60' race wt. 3695##
RWHP 324.5 / RWTQ 319.6 Dyno done by FLP
Old Aug 21, 2002 | 03:55 AM
Ken95Z28's Avatar
Post
If you get a stall you better get some better hooking tires.
You really should see the times drop than.
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Mac Header & Y-pipe, Flowmaster Exhaust, CutOut, Yank ST3500, TransGo Shift Kit, LT1 ScanMaster, CSI WP, M/T ET Streets, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28
F-Body Fastest List
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
dgPltt
Feb 11, 2015 07:04 AM
camy 1993
Feb 3, 2015 06:26 PM
Jan 23, 2015 01:13 PM
warmeck
Jan 20, 2015 10:29 PM
