hot cam install trouble with overheating/poor runnin'
Old Aug 18, 2003 | 08:25 AM
25thAnnTA's Avatar
ive been battling some troubles after heads/hotcam/electric water pump install.. I had to eliminate the aluminum coolant tube passing from the back of the drivers sides to passenger side head. i screwed in a barb and connected a heater hose with a T in it between to the two, then ran another hose from the T to the radiater, right below the cap where the original piece went. ( the tube got bent up and i couldnt get the bolts to thread right in the head). Im having several issues. the car runs great when started and will idle cool in the drive for over 30 minutes. if i take it out for a short run, it often gets hot, runs like crap, and starts puking coolant from the overflow. it boils as well. been bleeding off air, but cant seem to overcome this issue. any ideas? i also had a bent pushrod and had to readjust the rocker arms.
Old Aug 18, 2003 | 04:17 PM
25thAnnTA's Avatar
anyone have any ideas here? im gettin ready to go home and try fixin' her up, but im not sure where to start. is this a blown head gasket or cracked head??
Old Aug 18, 2003 | 04:43 PM
Transamdriver's Avatar
If its pukin coolant from the overflow tank you could have hooked the hoses up wrong on the radiator. The little flimsy hose is suppose to hook up right under the radiator cap(Thats the overflow line) and the line that use to go to the TB but now goes you the back of your heads is suppose to go on the second one down from the cap.
Old Aug 19, 2003 | 09:16 AM
25thAnnTA's Avatar
will that make much of a difference? come to think-i actually hooked those up wrong. let me know
Old Aug 19, 2003 | 09:22 AM
BitCypher's Avatar
Oh yea that'll make a difference. Whatever is connected to the lowest connector is pressurized along with the rest of the coolant system - this should connect to the steam line that goes to the back of the heads (or to the TB if you haven't done the TB bypass mod). The top connector is used to bleed off excess coolant system pressure, thus it should be connected to the overflow tank.
Old Aug 19, 2003 | 09:56 AM
25thAnnTA's Avatar
let me see if i have this right.... the line from the back of the passenger side head goes to the second line down below the radiator cap-the one directly below is for the overflow-right? (man i would LOVE it if this were my problem!!!)
Old Aug 19, 2003 | 10:48 AM
BitCypher's Avatar
Yes.
Old Aug 19, 2003 | 10:51 AM
25thAnnTA's Avatar
WHEW! i was gettin pissed, tryin to purge the coolant system and having it boil over constantly!!! this REALLY helps-thanks guys!!!
Old Aug 19, 2003 | 10:53 AM
BitCypher's Avatar
I hope this is the fix to your problem. Anything for a fellow f-body enthusiast (or MOGMHP member )!
Old Aug 19, 2003 | 10:59 AM
25thAnnTA's Avatar
Thanks brother!! r u a member of MOFBA here in KC? do you frequent kcir?
Old Aug 19, 2003 | 12:07 PM
BitCypher's Avatar
Sent you a PM. Also, I wanna know what you think of the LT4 hot cam after you get things running "cooler". I'm going to do the same installation over this winter (that or the XE 227/233 from combinationmotorsports.com).
Old Aug 19, 2003 | 01:18 PM
25thAnnTA's Avatar
Sent pm back. still too darn early to tell on the hot cam..... if i can get a 12 sec outta her, I'll be content with it................for now!
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
