Hot Cam: before and after (READ!!)
I think my car dynoed 325 rear wheel with about 340 ft-lbs way back when I originally installed the LT4 hot cam along with 1.6 RR's and Hooker shorty headers. I was pretty happy with the numbers at that time. It was only AFTER I did an ECM reprogram that I really understood how much dyno tuning was good for. I went from a REALLY rich 325 rwhp (along with a 13.60 at 102) to a clean smooth 349 rwhp with 355 ft-lbs (as well as a 12.89 at 106+ mph). Some people might disagree and say its not needed...but in my case...ECM and Dyno tuning was worth quite a bit to my car.
Originally posted by Like My Taillights?
How much did they charge to install the kit?
As far as 350....I prolly won't make it but I know some people on here who are close....so that gives me some hope
Just installed my hotcam/headers and ppd heads.
Changed all the seals, even the rear main seal and installed SLP clutch.
I have a idle dropped that appears to be from my Idle Control Motor. Pulled it and it full of carbon with cracked seal. I dropped of the seals to my mech today for the throttle body and Idle Control Motor. I'm anxious to put some miles on the new clutch then get it to the track for some numbers.
[QUOTE]Originally posted by ninjatertl
[B]
It woulda cost less but a bunch of stuff went bad that they had to replace.........
[B]
Originally posted by 95TA8280
$1300
damn you got jacked. $1300? did you shop around for pricing before the cam install?
$1300
Originally posted by weaponZ
i was under the impression my hotcam kit would give me 50-60 more HP.this is alot of work for 25HP
The HOT Cam's awesome, not sure of the real numbers that it gives you but the Cam along with full exhaust gives you a good pull in power.. My buddy has a Hot Cam Kit in his 94' 1LE and that cars one of the top dogs in our area.. The car runs low 12's @ 113mph, what more can you ask for out of stock heads right? The Mustangs in the area all spray him with 150 shots just to run with him, granted some beat him by a little and some get beat but for having just a cam and exhaust you can't beat the power gains for as much as it costs..
I drove his car more than once and its alot more than i expected, not to mention the 100 shot he has to barey them stangs, they spray 150 at him, jump ahead a car length, then he sprays them with a 100 shot and jumps out 2-3 car lengths on them
