Hot Cam in a 94??
Old Oct 18, 2005 | 11:34 PM
"White Knight"'s Avatar
Hot Cam in a 94??
Alright I searched and couldn't really find what i needed. I need to know what all needs to be done to the cam to work with a non-vented opti set-up. I think I remember hearing that just the dowel pin had to be milled down a little, but can't remember if that is all.
Old Oct 18, 2005 | 11:49 PM
Mean Green Z28's Avatar
Re: Hot Cam in a 94??
I'm not sure about that 'cos the early LT1 cam has splines in the middle to accept the opti. Check the middle to see if it has splines and how it'll accept the opti.
I was having issues with my non-vented opti everytime the weather got crappy so I switched to a vented opti when I did my cam. You'd to get the timing cover from a '95 and the vacuum lines that run from the intake to the opti and then to the intake manifold. I made my own lines using vac. tubing. Haven't had a problem since.
Old Oct 19, 2005 | 07:45 AM
As long as the dowel pin clears the timing cover (and it probably will), there is nothing to do.
Old Oct 19, 2005 | 07:51 AM
If you did your own vacuum lines, you should have included the two blue discs that come on the factory harness. The one that reduces vacuum is especially important as to keep from sucking the opti together under periods of high vacuum.
Old Oct 19, 2005 | 10:44 AM
Dave89IROC's Avatar
the cam is not what had the splines, it was the timing gear that had the splines, all that is needed to run a newer cam(vented opti) on a early(non vented) engine is to cut the dowel down as needed to clear the timing cover
Old Oct 19, 2005 | 04:10 PM
Alright thanks guys, that's what I thought, just wanted a little reassurance before i place the order.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
