Hot Cam in a 94??
Hot Cam in a 94??
Alright I searched and couldn't really find what i needed. I need to know what all needs to be done to the cam to work with a non-vented opti set-up. I think I remember hearing that just the dowel pin had to be milled down a little, but can't remember if that is all.
Re: Hot Cam in a 94??
I'm not sure about that 'cos the early LT1 cam has splines in the middle to accept the opti. Check the middle to see if it has splines and how it'll accept the opti.
I was having issues with my non-vented opti everytime the weather got crappy so I switched to a vented opti when I did my cam. You'd to get the timing cover from a '95 and the vacuum lines that run from the intake to the opti and then to the intake manifold. I made my own lines using vac. tubing. Haven't had a problem since.
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
