hot cam?
Old Apr 19, 2010 | 08:01 PM
kevinz2895's Avatar
hot cam?
I got the motor out of my 95z28 and im about to put an lt4 hot cam in. Ive heard of people putting the lt4 knock module in as well with these swaps. They said that sometimes the stock module will retard the timing and cost you horsepower. Is there any truth to this and will it work in my car.
Old Apr 19, 2010 | 08:12 PM
andysc's Avatar
the cam alone probably won't dictate using a lt4 knock module. It is going to headers or roller rockers that make more noise which can cause the lt1 knock module to think it is hearing knock and retard timing. also going to a xfi type cam might make some extra valve train noise. But having said this a lt4 knock module is a good mod, and if you can get your hands on one I would. they seem to be getting harder to come by.
hth
andy schuck
Old Apr 20, 2010 | 05:25 AM
The LT4 knock module is specifically tuned to filter and eliminate the knock sensor signal caused by the noise from the Crane Gold 1.6x RR's that were used in the LT4 engine.
Old Apr 20, 2010 | 03:06 PM
kevinz2895's Avatar
just went to the speed shop today and im going to go with a cam from comp instead, and I do have the 1.6 rockers, and pacesetter headers. Is there anyway of knowing whether my module is retarding the timing in my car, and will the lt4 knock module work in my 95 z28 no problem.
Old Apr 20, 2010 | 05:38 PM
95zsean's Avatar
A tuner or a mail order tune can make your ECU less sensitive to false knock, which you will need if you use a larger than stock cam.
Have Fun.
Old Apr 20, 2010 | 09:49 PM
Use a scanner to observe knock retard under varous operating conditions. That will tell you if you have a problem.
Old Apr 20, 2010 | 09:52 PM
pro94lt's Avatar
with an assistant watching the scanner while you drive, LOL
Old Apr 20, 2010 | 09:54 PM
Not necessarily......
http://www.injuneer.com/images/photo.../DCP04287a.jpg
Old Apr 20, 2010 | 10:03 PM
Savannah Dan's Avatar
No passing on a solid yellow line! LOL
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
