Hot Cam in!
Old May 28, 2006 | 09:37 AM
1997formula's Avatar
Hot Cam in!
After almost 2years I finaly drove my car. It started off as a blown head gasket, and then I got a case of the (I might as well's). I bought a used engine (18'000) Had the heads shaved and valve job, bought the hotcam kit, new timing chain, all new gaskets, Slp shorties + loudmouth, k&n, MSD wires, prothene mounts, madz28 tune, cleaned and painted everything including the engine bay. I also got a fuddle 3400 stall +transgo+cooler. Theres probably 20 other things I bought, but thats the main stuff. It started right up, and sounds MEAN. I love it. The question I have is should these rockers be completely quiet? I've read many posts about this, and most say they should make noise. Mine are making a little noise, when you put your ear down near the valve cover. I had a mechanic look at the car and he said they should make no noise. Thanks to everyone who answered any questions I had over the last two years. I couldn't have done this with out this web site. thanks
Old May 28, 2006 | 09:41 AM
Car Enthusiast's Avatar
Re: Hot Cam in!
report back with some dyno numbers man tell what all that hard work accomplished
Old May 28, 2006 | 09:43 AM
MyShibbyZ28's Avatar
Re: Hot Cam in!
Does the mechanic specialize in LT1's? They will make a little noise, that's why people switch over to the LT4 KM.
Old May 28, 2006 | 09:52 AM
Re: Hot Cam in!
The mechanic said he worked on a couple of stock lt1's. This is the only thing I'm worried about, because after all this time I don't want to break something.
Old May 28, 2006 | 10:29 AM
joeSS97's Avatar
Re: Hot Cam in!
Roller rocker are nosier than the stock ones.They will sound like a sewing machine.Now if its a loud clack,they are probably too loose.
Old May 28, 2006 | 11:47 AM
FastZinTennessee's Avatar
Re: Hot Cam in!
The rockers that come in the HOTcam kit do make some light tapping noise- it is normal.
Your mechanic is right about the stock rockers, they should not make any noise.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
