horn
Old Jul 26, 2003 | 09:30 PM
oaklandz28's Avatar
horn
my horn buttons are gone for some reason i dont know why. I bought it like that. i want to put the buttons on and i was wondering how do i take the cover off the steering wheel and if i did will the air bag pop out on me?
Old Jul 26, 2003 | 10:49 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i don't think you CAN "remove" the cover of the airbag in the wheel... whats keeping you from just buying the buttons and putting them on?
Old Jul 26, 2003 | 10:51 PM
White96Z's Avatar
It's very easy to remove the cover/airbag module. Yes, the airbag could deploy if you don't do the following: 1) disconnect the battery 2) make sure the steering wheel is straight and in the locked position 3) remove the air bag fuse 4) unplug the yellow CPA connector under the right side of the instrument panel.
After that there are four screws in the back of the steering wheel. Then remove the airbag module and disconnect the electrical connector. Then you've got it disconnected! Hope this helps!
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
War Engine
Aug 28, 2015 06:04 AM
fpete1992
Dec 11, 2014 03:51 PM
Shorty95Camaro
Aug 29, 2003 12:21 PM
95Z-Cross-Eyed
Aug 5, 2003 01:38 AM
