Hooker shorties question
Old Feb 6, 2005 | 09:19 PM
ddj19852003's Avatar
Will the hooker shorties for 93 Z fit the 94 Z what is the difference in the fitting need help with this asap
Old Feb 6, 2005 | 10:50 PM
Bud M's Avatar
Re: Hooker shorties question
Smog fitting is different on the passenger side header, otherwise the same
Old Feb 6, 2005 | 11:17 PM
the smog fitting being different is that a problem can the headers still be installed and smogged or no?
Old Feb 7, 2005 | 08:45 AM
someone please answer the second question thanks
Old Feb 7, 2005 | 09:20 AM
DarkHorse's Avatar
I believe they can still be used but a different adapter needs threaded in? Headers should be fully functional/emissions compliant once you get the threading right. Contact Hooker or do a search on the board - I know this was discussed previously as I ran across the info while researching the headers before I bought them.
BudM helped a lot with the opening of the collectors - even tho I still haven't done it yet ;p
Old Feb 7, 2005 | 01:16 PM
Evil Eric's Avatar
their might be some fabricating involved. you could always just strip the emissions.
Old Feb 7, 2005 | 08:07 PM
Bud M's Avatar
The difference is the AIR system plumbing. On 93s the pipe is different and it threads into the header. On 94s the pipe bolts on. As far as passing smog the only way would be to replace the 94 AIR system with the 93 setup and hope they don't know the difference. Probably more trouble than its worth.
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
ModdedNerd
Jan 1, 2015 10:56 AM
smacz28
Aug 6, 2002 01:51 PM
ferraricameron
Jul 29, 2002 07:46 PM
