hooker LT clearance issue, need some help
Old Jul 16, 2004 | 07:38 PM
BlackbirdWS6's Avatar
well after finicking with my Y-pipe so it doesnt bang, i am noticing that the passenger side header is extremely close to the lower front suspension if u kno where im talking about. Its right before the collector. anyway, its not touching but i would imagine with my engine moving around it is bangin but its intermittent. Anyone have a similar issue and/or have a solution to it?
Old Jul 16, 2004 | 10:01 PM
SS1304's Avatar
Same here....
Old Jul 18, 2004 | 06:23 PM
Re: hooker LT clearance issue, need some help
well should i be happy or mad that u have the same issue heh. anyway, anyone have a good solution i can do myself. My sometimes crazy mind says to stick something non flamable there so it wont do it but I'm open to other suggestions. the place i have my exhaust work done at says he could heat it up and squish the pipe a bit but said it would weaken the metal...I can see that being a problem later on.
Old Jul 19, 2004 | 03:56 AM
1 Nasty Bird's Avatar
What you need here is a BFH Big Freakin Hammer. bang the pipe or whatever is close to it, whichevers least important i guess
Old Jul 19, 2004 | 11:04 AM
LWillmann's Avatar
My LT headers were REALLY close to the k-member on the passenger side, replacing the motor mount fixed my problem.
Old Jul 19, 2004 | 11:20 AM
Guggi97_RA's Avatar
i used a big *** crow bar and did a little modifying.......
Worked great...
ADam G
Old Jul 19, 2004 | 12:11 PM
think ill try the persuasion technique of Guggi, if that doesnt work then ill try replacing the motor mounts. thanks
Old Jul 20, 2004 | 12:28 PM
SS1304's Avatar
I just ordered a set of polyurtherine <SP?> bushing for the motor mounts and trans mount from thunderracing and we will see if that helps so I will let you guys know in a few days when i get them put in. If that doesn't fix the problem I'll get a big *** wrench and fix it.
Old Jul 20, 2004 | 02:53 PM
Guggi97_RA's Avatar
Those mounts are going to vibrate the living heck outta you !!!!!
My poly tranny mount is a vibrating FOOL !!!
Adam Guggi
jasonduaine
Apr 1, 2015 08:09 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
