Hooker Longtube guys
Old Mar 20, 2006 | 05:53 PM
sick-1's Avatar
ok trying to get these new headers put on so i can finally start the new stroker setup but.... having trouble installing the passanger side header. Do you have to jack the moter up on that side to get it in or what. (wish i would have put it in when i had the tranny out a few days ago now.)
Old Mar 20, 2006 | 05:55 PM
2000GTP's Avatar
Re: Hooker Longtube guys
Jacking up the motor a little bit or popping off the passenger valve cover are a couple of tricks that get the job done.
Old Mar 20, 2006 | 06:20 PM
sick-1's Avatar
i tried the vavle cover idea but couldnt get it to go. guess nothing left to do but jack it up, thanks for the help
Old Mar 20, 2006 | 06:56 PM
LtsRace's Avatar
What got it in for me was jacking the car up VERY high. Dangerously high, then it slipped right in. I had to put my jack on cinderblocks with plywood on top. Make sure to invest in the good jackstands for safety reasons
Old Mar 20, 2006 | 07:11 PM
Josh'95Z28conv's Avatar
Just take the motormount loose, and jack up the engine several inches. It will go right in.
Old Mar 20, 2006 | 07:33 PM
NVRLATE's Avatar
I didn't have to jack the motor up but I did have to jack the car very high.
Old Mar 20, 2006 | 08:38 PM
matLT1's Avatar
I had to remove the valve cover, alternator, dipstick, and the heater hose that runs along side the engine. Do this plus lift the engine up (just the passenger side) and they will drop right in.
Old Mar 20, 2006 | 08:44 PM
hotrod18_69's Avatar
Same here.. Went right in.. Take the alt. off makes it easier to get your hands in from up top to put the bolts in.. And ofcourse make sure the start is off.
Old Mar 23, 2006 | 05:12 AM
Guest47904's Avatar
Guest
I didn't have to touch the motor mounts on mine. That was before I got the 2 post lift and had to get it way up off the ground to get them in from the bottom.
I guess the next post will be "I can't get the motor mounts to line up"
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
Achilles97
Sep 13, 2002 10:49 AM
Red97LT1
Aug 7, 2002 05:45 PM
