Hooker Header Problem!
Old Dec 29, 2003 | 07:01 PM
Kryckter's Avatar
I have hooker long tube headers on my 97 trans am, well the install was pretty easy and didnt have too many problems. After i put them on i have had a ticking sound from the driver side. I re-tightened all the header bolts and its still there. I thought maybe it was a rocker so i readjusted them several times. Come to find out it is an exhuast leak! Coming from the front primary on the driver side. Everyone with headers knows how the make this front primary removable to make install easier. Well, where the two tubes connect it leaks, pretty bad, and i didnt sand on it or anything to make it fit, slide right on with some convincing....How do i fix this?!?!?!?!?
Old Dec 29, 2003 | 11:06 PM
Austin96Formula's Avatar
I used one of those t-bolt clamps. Most marine shops should have them. I've also heard of people having the slip fit welded...
Old Dec 29, 2003 | 11:13 PM
turbostud2's Avatar
i used high temp silicone and a clamp no leaks here
Old Dec 29, 2003 | 11:23 PM
SloLt1Z's Avatar
I used a good glob of the orange high silicone and it was all good
Noenav
Mar 1, 2019 07:38 AM
QuickSilver02
Apr 7, 2015 11:12 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
