hood latch cable disconnected...how can I get hood off?
Old Jan 19, 2004 | 12:27 AM
96LT1TX's Avatar
Ok, I've done it now. I've done somethin I can't fix. The latch is connected on the hood, and the cable is disconnected from the latch. its on a 1996 formula and we really need to get under the hood to get the belt on... so we can run it!! just did a cam (230/236 112) and it idles nice, just need to get this latest problem fixed... any help appreciated...
Old Jan 19, 2004 | 12:36 AM
Heatmaker's Avatar
Advanced Member
where did the cable come off at exactly?
Disconnected from the Pull lever...or the rleasing latch it'self?
Old Jan 19, 2004 | 12:38 AM
96LT1TX's Avatar
Post
it was never reconnected in the first place... I was in other room and someone shut hood so now I need to get it open so I can run it!! plz help
Old Jan 19, 2004 | 01:36 AM
Heatmaker's Avatar
Advanced Member
aLl i think of is taking out the head lights and trying to get to the latch somehow that way...difficult but....what else is there...? unless there's a way to reach if and rlease it from under the car...but I think the radiator equipment would be in the way.
Old Jan 19, 2004 | 07:47 AM
96LT1TX's Avatar
any other ideas??? need to get hood off!!
Old Jan 19, 2004 | 08:00 AM
BC94Formula's Avatar
someone???
Old Jan 19, 2004 | 12:17 PM
Zachz28's Avatar
sawzall
Old Jan 19, 2004 | 01:11 PM
96LT1TX's Avatar
well, today I am going to jack the car up and start taking brackets and hopefully enough stuff out of the car enough so that I can clear to the hatch... wish me luck... any other ideas?
the lights are already out of both sides, still no room to reach hatch.
Old Jan 19, 2004 | 01:15 PM
trax's Avatar
If I remember correctly you should be able to pull out a few of the panels below the front fascia, then undo the pushpins running in front of the radiator, and be able to squeeze your hand in there.... I think.
Old Jan 19, 2004 | 04:30 PM
96LT1TX's Avatar
yep, just had to get the 3 bottom tacks out of the front fascia... thanks for the help guys!!
Old Jan 20, 2004 | 01:35 AM
Fatdog's Avatar
Cool
Actually when my cable broke(among other things),I just used a coat hanger,bent the end ,crawled under the car,and with a flashlight,found the mechanism,pulled on it ,and it released.(I think I had to pull it to the left,or right,can't remember.Hope this helps.(Now,putting in a new cable,we are talking hours of fun.My02)(I don't remember removing any under car stuff though.)
Novo
Jun 14, 2016 02:58 AM
alliance12364
Sep 17, 2015 08:43 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Toxintwins
Sep 11, 2015 11:13 AM
Daluchman1974
Sep 11, 2015 06:12 AM
