Hole in top of head
Old Mar 16, 2018 | 06:45 PM
STLChris1221's Avatar
Hole in top of head
Is that giant hole supposed to be there? Been troubled by a cracked head or blown head gasket, saw this big hole. Looked irregular to me. The upper right hole under the rocker. This is above the #2 cylinder. Iron lt1 heads from a 94 roadmaster.
Old Mar 19, 2018 | 09:54 AM
Re: Hole in top of head
Well. Guess thats money saved for a pressure test.
Been wanting aluminum heads anyway. Time for a money consuming forged 383 rebuild.
Old Mar 20, 2018 | 10:39 AM
Ya. In stock form the irons flow a little better. I think its something to do with the larger valves. Dont quote me on that lol.
Old Mar 20, 2018 | 09:58 PM
When you get the aluminum heads, have them ported by someone like Lloyd Elliott. They will seriously outflow the iron heads, you will save 45-50# off the front end, you will have a higher compression ratio, be able to run more ignition timing.
Being able to see the lifter is a dead giveaway something isn’t right.
Old Mar 20, 2018 | 10:11 PM
Depends on if money allows for me get porting done by Lloyd.
But plans for the LT1 would involve AFR 195s(larger if I do a stroker) a cc306 or lunati 60122 cam, Scorpion 1.6 rockers, beehive springs, McLeod clutch, forged internals, and supporting goodies.
Old Apr 5, 2018 | 07:49 PM
sbs's Avatar
sbs
A quick google search indicates this is normal
starbucks
Oct 25, 2008 09:28 AM
Jay-Roll
Mar 24, 2004 02:46 AM
marshall93z
Nov 18, 2003 10:41 AM
96 WS6
Jun 30, 2003 05:39 PM
