how to repair hole in head?????
my dumba$$ was grinding in the bowl around the valve guide boss and i poked through into the water jacket!!!
is there an easy way to fix this or do i have to have it welded up at a shop?
Re: how to repair hole in head?????
Lake Norman Engineering
D.O.A. Racing Engines
Aren't they nearby?
There's always DEI.
i didnt know those race shops would do stuff for the public.
Forget DEI. Even if they would, you probably couldn't afford them!
how did you know about them?
If you aren't putting holes in stuff now and again, you either aren't trying, or have some magical castings with no core shift
It depends on what you did really. In all likelyhood, it can be fixed by having it welded. After it's welded however, you really need to pressure check the head again, b/c if your work is consistent, you've likely gotten too thin elsewhere as well. That and leaks can be a PITA at times when cracks or porosity come into play.
You'll also probably end up having to replace that guide & hone it to size - depending on where exactly you're welding.
Isn't porting fun
.It depends on what you did really. In all likelyhood, it can be fixed by having it welded. After it's welded however, you really need to pressure check the head again, b/c if your work is consistent, you've likely gotten too thin elsewhere as well. That and leaks can be a PITA at times when cracks or porosity come into play.
Isn't porting fun
