Hitting the rev limiter
Old Aug 26, 2004 | 07:40 PM
  #16
kyzar24's Avatar
Re: Hitting the rev limiter
just some info on gears and stall the computer will not pick them up if they did your speedo wouldnt be off also the 94 95 z28 have stall wall problems which wont let them shift my car has a 2,000 dollar built tranny in it and it bounced the limiter with gear and stall got car dyno tuned a year later no rev limiter
Old Aug 26, 2004 | 10:10 PM
  #17
KillWhitey's Avatar
The tranny shifts fine until he floors it. When it hits the rev limiter it just bounces off of it. until he lets off of the gas then it shifts. When he drives normal it shifts normal. Even under hard acceleration. it just does not shift when he hits the rev limiter until he lets off the gas. then it shifts very hard with no slipping.
Tim
Old Aug 26, 2004 | 10:54 PM
  #18
z2894convertible's Avatar
Lightbulb Re: Hitting the rev limiter
Originally Posted by Z06Z28
I would jump back in that car at WOT and take it up the RPM band without hitting the limiter and see how it shifts through the gears before ruling out that he has a bad tranny. Is he using Dextron? I dont think he's allowing the tranny enoughtime to shift at high RPM so gets spooked he just lets off. Before my firm shift tune..my car sounds like it was doing the thing as your buddies...I would take it to the limit and since the stock shift is so soft..it kinda takes a few seconds but I wait until it shifts finally. I got sick of that so I did a tune and added a firm shift and my car seems to be WAY better at shifting when progressing to high RPM at WOT. I thought I had a different car...anyhow I use Dextron and I noticed a better shift with it over other brands I have used as well. I would totally try some options before telling him bad news that might not be so sure...
What you said makes no since. Reread the post and look at the facts, then post again.
Old Aug 27, 2004 | 04:28 PM
  #19
Z06Z28's Avatar
omg man..whatever. It really doesnt matter to me what you pump that guys with....go ahead and tell him to ditch the tranny. pfftt
Old Aug 27, 2004 | 05:33 PM
  #20
KillWhitey's Avatar
Thanks for all the help. I told him to be prepared to drop a nice chunk of change on a new tranny.
Tim
cristian1311
Apr 22, 2015 10:20 PM
armedtrigger
Feb 24, 2015 08:30 PM
Rbain
Sep 4, 2002 12:35 PM
Nostang 96z
Aug 31, 2002 12:01 PM
jp2002ls1
Aug 30, 2002 08:18 PM
