hitting rev limiter
Old Jun 3, 2004 | 11:26 PM
camaroKid223's Avatar
Question hitting rev limiter
hey i posted about this once before but now have alittle more detail about it. At around 85 if i hit the gas hard the car sounds like it hits the limiter untill i let off and hit it again. the odd thing is that when i looked down at the rpm's today they seemed way to low to be hitting the limiter, around 4000-5000. Any clue as to what this is, oh and other then this the trans shifts strong so im not sure if its trans related or not.
Old Jun 4, 2004 | 12:02 AM
OBE1 95Z28's Avatar
Sounds like you have a miss at 4K - 5K rpm. I'd look for arcing of your spark plugs wires. Let the engine idle in the dark and look for arcing from the wires to the block/exhaust manifold. Your plugs may need to be changed also.
Old Jun 4, 2004 | 11:14 AM
Smile
ill do that tonight, thank you last time i posted about this all i got was "time for a trans rebuild"
cristian1311
Apr 22, 2015 10:20 PM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
