High rpm miss
Old 07-17-2003, 08:53 PM
jasons93z's Avatar
High rpm miss
I have a miss at between 4500-5500 rpm. It only happens in 2nd that ive noticed, not in 1st. It only happens in the heat of the day when the car is running hot. Whats your thoughts?
jasons93z is offline
Old 07-17-2003, 08:57 PM
RedPhenx's Avatar
check your cat,
or less likely check for burned out plug/wire
RedPhenx is offline
Old 07-17-2003, 09:00 PM
jasons93z's Avatar
i have no cat. i have a new coil so its not that. but i will check the wires.
Old 07-17-2003, 09:04 PM
RedPhenx's Avatar
I just noticed off road pipe
RedPhenx is offline
Old 07-18-2003, 01:10 AM
Izod's Avatar
Dunno if its related but the 3100 series engines had a very similar problem. Not much but thought I'd throw some trivia your way see if it sparks anything in your mind.
Izod is offline
lt1matt
03-21-2015 07:35 PM
carl.froehlich
03-13-2015 12:38 AM
1996LT1Z28
03-08-2015 08:16 PM
DetroitZ28
02-13-2015 07:33 AM
sleeperZ96BT
06-05-2005 09:33 PM
Quick Reply: High rpm miss
