high rpm
Old Aug 25, 2011 | 04:14 PM
awill12's Avatar
high rpm
i have a stick shift car and when ever i take it out of gear for a stop or shift the rpms will hold at about 1500 for a fews seconds then drop down? what could be causeing this? it just stared doin this, before it would rev right down to 900?
Old Aug 25, 2011 | 04:50 PM
Re: high rpm
When the car is moving, the PCM holds a higher idle speed. It won't settle down to the normal idle speed (800rpm for the M6) until the vehicle has fully stopped.
If you feel it's higher than it was before, check the throttle cable and the blades to make sure it's returning to fully closed when you release the pedal.
blac94Z
19
May 13, 2015 04:50 PM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
PhantomTA
Aug 17, 2002 12:19 AM
