High miles and cam?
Old Apr 17, 2005 | 12:05 PM
  #16
WS6NIGHTMARE's Avatar
Re: High miles and cam?
Itll cost you alot more if they pull the motor, do the work and reinstall it. You should get another LT1 block and rebuild that, then do the swap.
Old Apr 17, 2005 | 12:23 PM
  #17
brain's Avatar
I ingored the bearing failures when I did my first cam swap, figuring it was sloppy install or user error. I took every precaution I could and was meticulous. Still happened. I definitely recommend a new oil pump if you are doing a cam swap. Its cheap insurance.
Old Apr 17, 2005 | 08:23 PM
  #18
2000LS1Z28's Avatar
http://forum.fbody.us/showthread.php?t=35311
Read that entire thread of the link I pasted above...I started it on my local F-body club site asking the same type of question (my situation is VERY similar to yours) and got a lot of interesting and great feedback from those that had experience...
BTW, I PM'd you...
Good luck,
Mike
rideordie
Nov 5, 2019 04:52 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
