High Mileage Oil
Old Jul 15, 2004 | 11:54 PM
eagleknight97's Avatar
Question High Mileage Oil
Anybody got any experience with Valvolines High Mileage Synthetic? I bought a case of it for my oil change, on a whim, and was just wondering if anyone has any experience with it. Car has 96K on it, just if anyone was wondering. Thanks
Old Jul 16, 2004 | 12:03 AM
disco192's Avatar
Its BS. If you are really worried, throw a can of RESTORE in it and run good synthetic oil like Mobil 1 0w40 or German Castrol 0w30.
Old Jul 16, 2004 | 08:43 AM
96capricemgr's Avatar
High milage oil is B.S. but Restore is good . The high milage oils can provide some cleaning and seal conditioning benifits, restore on the other hand will not go into anything I own.
For all your lube question why not go to a site where the info is more scientific and less opinion. Here is a link about restore on just such a site. http://theoildrop.server101.com/cgi/...c;f=5;t=000538
Old Jul 16, 2004 | 09:27 AM
grygst76's Avatar
High mileage oil has more sealants and cleaners in it. It does not hurt to run it, its only a tri-synthetic and it works pretty decent, but it's usually only for vehicles over 75,000.
Old Jul 16, 2004 | 09:56 AM
gamecockfan04's Avatar
All I have used is Valvoline High Mileage in my car and have had no problems. It has more conditioners and sealants the regular oil, so as said above it cant hurt anything.
Old Jul 16, 2004 | 10:19 AM
CamaroZBoy's Avatar
Just run Castrol 20w-50 and ull be fine....
Old Jul 16, 2004 | 11:35 AM
That oil is just a lil thick for winters up here in Northern Illinois
Old Jul 16, 2004 | 02:22 PM
CamaroZBoy's Avatar
very tru...its hot as hell down here in south florida all the time....never really gets cold at all...nothing a long sleeve shirt can fix..
Cory
Old Jul 16, 2004 | 04:31 PM
HardcoreRM125's Avatar
Patman, the oil guru, has a higher mileage LT1 as far as I know, and he is running Castrol Syntec, the german stuff though.
As far as I know, it seems like he really rags on his car ( In on thread a while back he said he floors his car at least once every time he drives it lol ) and says that the oil samples have showed virtually ZERO wear.
Old Jul 16, 2004 | 05:47 PM
revtime's Avatar
I have 146k on my LT1 now and have been using the Valvoline high mileage oil since about 100k, I tried mobile synthetic but my car leaked like no other put the Valvoline back in it and I only see a spot every once in a while.
For what its worth........
Old Jul 16, 2004 | 05:51 PM
crAzy95z28's Avatar
i use mobil synthetic high mileage!
Old Jul 16, 2004 | 06:57 PM
n2ceptor's Avatar
http://www.lubereport.com/e_article000200588.cfm
Old Jul 16, 2004 | 10:46 PM
Patman runs the 0w-30. 20-w50 is a bit much and you run the risk of pumping up the lifters which could slightly hang the valve open when it should not be.
Old Jul 16, 2004 | 11:50 PM
1racerdude's Avatar
20W-50W won't hurt anything in your engine including the lifters.It will be good to 32*F and then you will need to go to a 10W-30 for cold cranking.In our service trucks in Alaska that is what we ran except when it got to 0 or below we didn't ever shut them off.We also kept them pluged up to block heaters while they were running below 0.
HectorM52
Jul 30, 2017 11:46 AM
ad356
Apr 11, 2015 08:49 AM
carl.froehlich
Mar 13, 2015 12:38 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
