high or low pressure fuel pump?
Old Mar 24, 2004 | 03:20 PM
MonoxideChild's Avatar
mods in sig.
I'm going to guess high pressure cause it's regulated at the FPR. but, what do you guys run?
thanks!
Old Mar 24, 2004 | 03:24 PM
A "low pressure" pump is usually intended to supply a carb setup at 7psi. A "high pressure" pump is intended to supply a high pressure fuel injection system, at 35-50psi. We need a "high pressure" pump.
Old Mar 24, 2004 | 03:57 PM
makes sense to me.
thanks!
Jan 23, 2015 01:13 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
