How to disconnect the temp gauge?
Old Mar 24, 2004 | 03:58 PM
Evilfrog's Avatar
Anyone know how to disconnect just the temp gauge? Without hurting anything?(causeing the engine to throw codes or confuse the PCM)
Old Mar 24, 2004 | 04:04 PM
SweetZRag's Avatar
The temperature guage sensor is not connected to the PCM so you can disconnect it without any problem. It is located on the left side in the head just under the exhaust manifold between the front two spark plugs.
Amped96's Avatar
The reading for the guage comes from a sensor in the driver side head. Just unplug it and that will keep the needle at 0. Why do you want to do this?
The PCM will still know the temp, because it gets its reading from another sensor (in or near the waterpump I believe.)
jhaase
3rd Gen / L98 Engine Tech
20
Oct 4, 2015 05:10 PM
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
