High Idle...is this normal?
Old Mar 31, 2007 | 08:25 AM
micfly83's Avatar
At times my car (m6) will idle at 1500 rpms for pretty long periods of time.
On initial startup itll just sit there pegged at 1500 and then even when I drive it'll continue to be at 1500.
Sometimes it'll return to normal and idle at like 800-1000, other times it will continue to stay at 1500 even when the engine is warm.
Is this normal?
Old Mar 31, 2007 | 08:35 AM
Not normal. Idle speed is increased only when coolant temps are low. And it never sets the idle at 1,500rpm. The stock programming for an M6 is:
COOLANT
TEMP
deg F
-40*F: 1,200rpm
-19*F: 1,050rpm
+3*F: 1,050rpm
+24*F: 1,000rpm
+46*F: 900rpm
+68*F: 900
+89*F: 900
+111*F and above: 800rpm
Remember that the stock tach typically reads 100-200rpm higher than actual rpm. Better to read rpm off a scanner, direct from the PCM.
In any case, unless your coolant temp sensor is faulty (which would cause other problems, like preventing the PCM from entering closed loop), there is no reason for the engine to idle at 1,500rpm at any time.
You might also want to check the throttle position sensor (TPS). If its reading above 0.90V at closed throttle, it can cause the PCM to hold higher idle speed. But that should also set a code.
Have you verified that the throttle blades and cable are moving freely, and that the blades are closing fully at idle, all the time?
Have you checked for vacuum leaks? Again, a scanner can help you, because you can watch how the IAC counts respond to the higher than programmed idle speed. Possibly the counts are bottomed out at "0" and the IAC motor can't control the idle.
Hve you checked for a tear in the inlet elbow, or the bottom edge being folded under and not on the throttle body?
Old Mar 31, 2007 | 09:06 AM
micfly83's Avatar
COOLANT
TEMP
deg F
-40*F: 1,200rpm
-19*F: 1,050rpm
+3*F: 1,050rpm
+24*F: 1,000rpm
+46*F: 900rpm
+68*F: 900
+89*F: 900
Well I've never used a scanner or anything like that, but I guess its time to learn. Is there a link on where to get them or rent them and how to use them.
And I haven't checked real recently, but I did have to fix that at one point as the elbow edge was folded back on the throttle body.
Old Mar 31, 2007 | 01:01 PM
You can use a hardware scanner like the ones made by Auto-Xray or Actron (not the $30 shorts-the-pins code reader), or get software for a laptop from Freescan (free download and use), TTS DataMaster (free download and 20 uses), EFILive V4 (costs) or pcmcomm bundled with LT1_Edit. Get a cable from AKM Electronics.
The "problem" with your 95 is the fact that it has an OBD-I PCM and an OBD-II ALDL connector under the dash. AKM makes a cable specifially for the 95. Auto-Xray has an adapter plug for their OBD-I scanner. Or, if you have the full OBD-I cable, Shoebox has a photo showing how to jumper the 12-pin OBD-I cable pins to the 16-pin OD-II ALDL connector.
I have an online guide to reading scan data for the LT1:
http://members.aol.com/InjuneerZZ/ScanMast.htm
AtlasXVIII
Aug 2, 2015 10:29 AM
ad356
Apr 11, 2015 08:49 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
jasonduaine
Mar 7, 2015 09:44 AM
super83Z
Jul 21, 2002 02:43 PM
