High Idle
Old Jan 3, 2004 | 05:18 PM
Savannah Dan's Avatar
High Idle
Took a drive this afternoon and after about 10 minutes noticed that when I pushed the clutch in, the idle would hang at about 2 grand, then slowly drop to about 250 rpm higher than normal idle. Any ideas? Thanks.
Old Jan 4, 2004 | 06:54 AM
blk95z28conv's Avatar
rpm woes
sounds like a stuck valve
Old Jan 4, 2004 | 09:35 AM
Which valve would you be refering to? Thanks.
Old Jan 4, 2004 | 10:21 AM
Probably Idle Air Control (IAC) valve. It and the passages might need to be cleaned. The valve could also be lazy and need to be replaced.
I also think that it is not too unusual for the idle to remain slightly elevated on a manual trans car for a very brief time, like if you are purring along and just throw in the clutch.
Old Jan 4, 2004 | 11:07 AM
Thanks Shoe. This just started all of a sudden. The dang thing actually will stay at 2K with the clutch out. Kind of unnerving in traffic. I'll give the IAC a look. Thanks again.
Old Jan 4, 2004 | 11:20 AM
Also, you might want to look over your vacuum hoses. Make sure they are all on and replace any that are cracked or brittle.
Old Jan 5, 2004 | 11:31 AM
Took the elbow off and sprayed some carb cleaner in there and it runs fine now. Need to do a good cleaning on it though before it does it again. Thanks for the help.
Old Jan 5, 2004 | 12:54 PM
95patriotZ's Avatar
Where is the valve you guys are talking about, and how should you clean it?
Old Jan 5, 2004 | 02:07 PM
Here's the link to Shoebox's picture of the Idle Air Control (IAC)valve. It's on the lower passenger side of the intake.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
