high idle
Old Sep 14, 2003 | 05:25 PM
96Z28SilverStreak's Avatar
high idle
I think I may have messed up something...
last week I was cleaning my motor and removed the throttle body. I removed all the sensors and and cleaned it with b-12. I cleaned out all the carbon build-up thinking I was doing a good thing.
After aI put it all back together, when I crank the car it reves up to about 2k then slowly back down to 1k and idles there. I figured I may have damaged the IAC. So I ordered one from Jason and installed it. Still the same thing. Since then I have replaced the throttle body gaskets and checked all the vacum lines. I cant seem to find anything wrong.
Has anyone esxperienced this before or know of something I maybe can check??
thanks
Old Sep 14, 2003 | 05:31 PM
Zack's Avatar
is the 1k idle in park? because thats where mine idles
Old Sep 14, 2003 | 05:38 PM
it actually idles about 1100 - 1200 rpms. It is to high. before I cleaned the throttle body it use to idle at about 800 rps or so. Now when I am sitting at a light of stopping at one i have to use a likke more brake than normal. like she is wanting to take off.
Old Sep 14, 2003 | 06:35 PM
Is there any way to check the IAC, maybe I got a bad one, or is thre something after I install a new one to reset the comuter?
Old Sep 14, 2003 | 08:04 PM
96 WS6's Avatar
try resetting your IAC...
hold the gas pedal cracked open (not too far) and start the car and let it run for 5 seconds. turn it off for 10 seconds and then start it back up again.
Old Sep 14, 2003 | 08:50 PM
Ok will try that tomorrow,
any other things I may check out? What about removing the IAC. Plugging it up and turning on the igntion to see it if moves out of in? can I test it like that?
Old Sep 14, 2003 | 08:59 PM
brandboZ28's Avatar
I did the same thing in cleaning the TB and mine is doing the same thing. Sometimes it does it and sometimes it doesnt. I dont get it.
Old Sep 14, 2003 | 09:29 PM
well surely there must be a something causing this, and a solution for it. I have spoken to serveral people who have run across this same problem.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
