Hey all, I'm back. Going to try this again...get the 383 running.
Old Jul 10, 2006 | 08:42 AM
  #91
TQdrivenws6's Avatar
Re: Hey all, I'm back. Going to try this again...get the 383 running.
The IAC count can certainly go to zero, that is when the computer is trying to lower the idle, but you either have the throttle blades proped too far open or you have a vacuum leak.
As far as the TPS voltage, .9v is the high limit of the computers acceptable range, and IIRC .2v is the low limit. The car goes into PE mode (WOT fueling and timing) when you hit a certain TPS value. So the legendary mod that you speak of would get you into PE mode at a lower actual throttle position. This isn't necessary in a car that is in proper tune, and the TPS is used for so many part throttle tables that I like to give it a larger range of values to work with.
Old Jul 10, 2006 | 09:01 AM
  #92
Dave88LX's Avatar
Yeah I probably have the blades cracked too far...
Thanks for the TPS info!
Old Jul 10, 2006 | 02:35 PM
  #93
1racerdude's Avatar
Originally Posted by Dave88LX
Gotcha...I think my IAC count is at ZERO right now, not sure how that works. I guess I have to close the TB blade some.
Curious...what's it matter between .45-.90V? As long as it's under 1V it shouldn't matter right?
One of the legendary "Mustang 5.0" mods is to set the TPS voltage to .98. Supposedly, it is in theory supposed to but you right on the edge of "off idle" in regards to TPS, instead of having to rotate the TB blades the distance required for .5V before the PCM realizes it's off-idle...something to think about I guess, maybe someone can chime in...
Mustangs are lean and the .95V is to richen it up quicker when ya get in it. Thats' mostly for stock ones too.
Old Jul 10, 2006 | 08:27 PM
  #94
MEAN LT1's Avatar
Wow, you have a stock cai, that need to be changed asap.
Old Jul 11, 2006 | 01:22 AM
  #95
Dave88LX's Avatar
Yeah I do. I ran out of budget.
"But it's got a K&N!!!"
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
cheapchevy
Apr 8, 2015 08:48 PM
nballisru
Dec 14, 2014 05:01 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
