Hey all, I'm back. Going to try this again...get the 383 running.
Old Jul 6, 2006 | 07:30 PM
  #61
Dave88LX's Avatar
Re: Hey all, I'm back. Going to try this again...get the 383 running.
Here's my plugs today. 0 miles, maybe 10 minutes of run time.
I'm guessing I have an exhaust leak on #8 back there eh? Hope it's just a loose bolt and not a blown gasket.
Old Jul 6, 2006 | 07:34 PM
  #62
1racerdude's Avatar
Ya definitely need to take some fuel out of it.
Old Jul 6, 2006 | 07:42 PM
  #63
Dave88LX's Avatar
Nevermind...they're all loose. Stupid tings.
Old Jul 6, 2006 | 07:45 PM
  #64
Dave88LX's Avatar
K let me talk to Ion and see what he thinks/can do for me. Thanks!
So you think it's a weeee bit rich?
Do you think a bad MAF would be causing all these issues?
Old Jul 6, 2006 | 07:54 PM
  #65
1racerdude's Avatar
If it's not measuring the incoming air correctly it will.
Did ya try your smaller injectors?
  #66
Kevin Blown 95 TA's Avatar
Those plugs look like hell. #2 & #4 looks wet - do they have fuel on them or oil? Does it run any better when you unplug the MAF and let it default into speed density?
Old Jul 6, 2006 | 07:58 PM
  #67
FastZinTennessee's Avatar
Good luck man, that's some ****ed up **** you are going through
My plugs did EXACTLY the same thing, this is why I'm at my wits end and about to pay someone to tune it! For your pocketbook and sanity I hope you get it sorted out soon.
Old Jul 6, 2006 | 08:01 PM
  #68
Dave88LX's Avatar
Kevin, I hadn't tried that yet. I do have a replacment MAF off of someone elses car though to try.
Reason I'm looking at the MAF is because of the Code 48...does that code throw off for much more than an actual bad MAF? Still working on the back 2 pass side plugs then I'll check the V on the 3 MAF wires.
Old Jul 6, 2006 | 08:03 PM
  #69
Dave88LX's Avatar
Yeah it REALLY sucks at $13/set! Adds up quickly.
I know what you mean about taking it to get tuned somewhere...I'm just hoping with the tune from Ion, datalogs, etc., that Ion can hook it up good! Or I want my "Unlimited tunes" fee back. j/k
I shot him an email and pointed him to this thread, we'll see what he says.
Old Jul 6, 2006 | 08:16 PM
  #70
You know, I recently looked at a scan for a guy with a similar problem and he had a MAF malfunction code and his BLMs were all out of adjustment trying to lean it out, and it turned out that he had a broken wire in his MAF harness.
Old Jul 6, 2006 | 08:21 PM
  #71
Dave88LX's Avatar
My BLM's are just 128/128 from what I can tell, they don't change at all. Is that what they call "split-BLM's" or is that something else? I've got to read up on BLM's...
Old Jul 6, 2006 | 08:29 PM
  #72
You aren't running the car long enough to have it go into closed loop (about 3 min), so it's just running off the open loop tables that's why the 128 blms not changing. Once it goes closed loop it will start adjusting and try to take out all that extra fuel.
Split BLMs are when it's running closed loop and the L or R BLM is higher or lower than the other by some appreciable amount - one side is richer/leaner than the other for usually a mechanical reason or maybe O2 sensor.
Old Jul 6, 2006 | 09:06 PM
  #73
Dave88LX's Avatar
So at first it runs off a programmed table, then once it warms up, it starts running in closed loop, where the PCM makes it's own adjustments?
At what point does it kick over toclosed loop? Is WOT closed loop also?
Plugs in, valve covers off...doing the rockers again.
Old Jul 6, 2006 | 09:31 PM
  #74
Closed loop is based on time and temp and O2 sensor readiness (I think)
WOT is not really closed loop in the sense that it ignores the O2 sensors and fuels off the MAF, enrichment tables, and saved BLMs (unless you have them locked to 128)
Old Jul 7, 2006 | 11:46 AM
  #75
SStrokerAce's Avatar
You could also have a intake gasket leak as well.... if there is oil on the plugs. The heads from Ai looked good in terms of valve seals and guides and I know we seated the rings properly that night ;-).
Bret
