hesitation? SES light? hooker long tubes?
Old Apr 14, 2003 | 11:50 AM
Green G0blin's Avatar
installed my hooker long tube headers.
soldered the 02 sensors..since they were too short.
am only running 2 rear 02 sensors.....
my car is a OBD2 ecu (96 formula)
my ses light blink then turns off..i checked the plugs and wires..they seem ok....
will the light blink cus im running only 2 sensors? instead of 4? since i havent gotten the the 02 sims yet?
also..will this car cause my car to hesitate? cus from 1500-3000 pms the car kinda drags..then it drives normal.
any help? thanks
Old Apr 14, 2003 | 02:52 PM
IllusionalTA's Avatar
when you say 2 rear o2's.. are you using hte one's after where the cat'sused to be? or the one's prior to? i hope theone's prior are the one's you are using.. As far as soldering.. i would have just gotten some o2 extender's they are pretty cheap.. The rear o2's w/o sim's will cause a ses but not a stumble.. Check all your connection's for the o2's mine did that when the wires were frayed from a bad bottoming out and getting wet..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
