help w/ spark/fuel problem
Old Sep 27, 2006 | 05:19 PM
  #16
96LT1TX's Avatar
Re: help w/ spark/fuel problem
BTW in the case of the 122 code, the PCM will use a default sensor value. It will not apply the torque converter clutch and will drop out of fourth gear when the tranny is hot.
the car is a t-56 so I do not understand this one.
For the tps, the volts coming to the sensor are waaaay low for what they should be. The 5v reference reads like .06v and the .2-.9v at idle cables read like .02 at idle, and should go up to 4.2-4.9, and it goes up to .16 or so. Should I replace the sensor and see if that fixes it? Or is it definitly wiring (I dont see how it could be the sensor personally).
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
