Help w/cam decision!
Old Apr 4, 2004 | 04:34 PM
  #16
jkipp84's Avatar
Here's a guide from Shoebox: http://shbox.com/ci/cam_removal.html
That's the cam removal guide, scroll down a bit and you'll see a table full of items for the swap. The follow on is the install.
Should give you an idea of what's involved. Good fun
Old Apr 4, 2004 | 05:12 PM
  #17
sc93's Avatar
Originally posted by MTL_Z28
What else did you need?
In addition to the cam kit, I replaced the timing chain and cam/crank gears ($150 for stock replacement), programming from Alvin at pcmforless ($150), miscellaneous parts I broke, plugs and wires ($70), gasket kit ($35), and some other stuff I can't think of off hand right now
Old Apr 4, 2004 | 06:12 PM
  #18
MTL_Z28's Avatar
I ordered a stock GM replacement timing chain but I didn't know it was also a good idea to replace the cam & crank gears also.
BTW Did you buy new lifters or did you use your stock ones (if so how many miles on them)?
PS sorry for hijacking the thread
Old Apr 4, 2004 | 06:47 PM
  #19
Cmr0z28's Avatar
its ok
97SSdude
Aug 21, 2015 09:36 AM
89 Iroc-z28
Jun 30, 2015 11:19 AM
cmsmith
Jun 4, 2015 07:35 PM
CR0067
Classic Engine Tech
Feb 11, 2003 09:42 PM
SmoknZ28
Jan 28, 2003 09:39 AM
