Help...Ticking at low rpms
Old Aug 17, 2004 | 02:06 PM
eep's Avatar
eep
I know much has been discussed on this and related subjects but I still wanted to post me problem and get some opinions.
I hear about 4 or 5 ticks only when I am on an incline in my parking garage going from a dead stop and just releasing the clutch. Question: Is this a problem with the engine or is it my low rpm driving. It seems if I juice it a little and ride the clutch a bit, I avoid the ticking.
Any thoughts would be appreciated. Thanks.
Old Aug 17, 2004 | 09:13 PM
n2ceptor's Avatar
Re: Help...Ticking at low rpms
Just sounds like your clutch engaging...Not sure though..... Try posting in the Drivetrain section, you'll probably get a better reply....
Old Aug 17, 2004 | 10:13 PM
eep's Avatar
eep
Unhappy Re: Help...Ticking at low rpms
Thanks for the thought. I checked it out better after work and now it seems to stumble off the line under hard? acceleration. I was thinking it felt like the timing advance was being taken out of the ignition but not sure. As far as the clutch goes, I have been nursing this clutch for a while, it does make some noice on shifts and sounds like a bit of a gear whine when I coast to a stop, but have never had problems with it engaging. I just put LCAs on the car this weekend but I'm not trying to lauch it off the line just medium/hard acceleration. Could the LCAs be causing that much additional traction to cause the clutch to finally have problems?
How can I tell if it's the clutch or the ignition? Is there simple check that I can do with engaging the clutch differently? I will also post it in the drivetrain section as you suggested. If I can't figure this out I will probably take it to the dealer sice I don't know a mechanic that I trust here in the Kingwood/Humble, Texas area. Help.
Navecm
Jun 1, 2015 05:57 PM
timmy39120
May 8, 2015 11:41 AM
Noenav
Apr 30, 2015 01:06 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
