HELP: Stalling - What sensors are used with/without MAF
Went to start a car after it's was parked for an hour and it just starts and dies immediately. If I give it a little gas it runs for a 5 sec, and stalls again. Disconnected MAF - car starts and runs almost normally (speed density, or just pre-programmed A/F ratio mode?)
I guess it's a MAF or some other sensor failing. What is the difference between how and what sensors used in these two modes? Any troubleshooting tips?
Thank you, I appreciate any help!
Might be an o2 sensor causing it to run rich or lean and just flat making it die. Or if your car is modded maybe your target idle vs coolant temps are set too low and the thing just wont idle when it gets 200 deg. Maybe tell us a bit more about the car than the year and the trans.
Thank you, guys. It seems to me I am having problems with MAF. Cleaned it, cleaned IAC valve, cleaned all contacts. It's still doing this even on cold and warmed-up (with disconnected MAF) engine.
O2 sensors aren't used to adjust AFR right after start up; the PCM waits approximately 3 - 5 minutes for the O2's to warm up and the coolant to warm up. Might check the fuel pressure to see if it's within specs. You could also have a leaky fuel injector causing a rich condition.
Thank you for all help! No codes (except old evap code I had for a long time and too lazy to fix and code for MAF, when it's unplugged; when it's plugged - engine is not running). This weekend MAF should come in, and I'll check fuel pressure and temp sensor.
One more question: how to check temp. sensor with multimeter? What resistance/voltage to look at? Thank you!
Shoebox has a guide to checking temperature sensors:
http://shbox.com/1/4th_gen_tech2.html#ect
Since you appear to have a scanner, can't you just use it to look at what the CLT sensor is reporting to the PCM?
Yeah just read your first post correctly. It must have been tired when I made my comment. It seems if there is a big difference when maf is unplugged, then it has issues. Good deal.
With MAF disconnected it was running "almost ok"
with following problems:- when engine was cold, throttle response was extremely bad
- low on power (very noticably!)
- when cruising on highway, and I let off the gas, RPM drop was so sharp, it felt like I was applying brakes
- I have no idea why, but it was running hotter
carguyshu
Jan 22, 2017 11:19 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
