HELP!!!!Smoke from dashboard------->
Old Jan 29, 2003 | 04:11 PM
vampyr95Z's Avatar
Well,I let the car warm up as I was getting ready to pick the kids up from school.I get in the car to leave and it's filled with smoke/haze and the stench of burned electrical items!
I shut it down right away and proceed to see smoke bellowing out of the speedo cluster area(definetly this side of the dashboard).I restart the car after a couple of minutes and no smoke but still the smell.
I just tried it again and the smoke came flowing out of the speedo area once more!The only electrical modification on the car is the Viper Alarm/Remote Starter/Starter kill and all that was installed September of 2000! This is the first incident like this.
Any and all replies appreciated!!!
Old Jan 29, 2003 | 04:21 PM
n2ceptor's Avatar
Time to remove the bottom panel a take a look.. If that the location were the viper was installed, look for wires that a burnt and see if a positive wire might have met medal... Hopefully it nothing major.....
93Z WIll
Old Jan 29, 2003 | 04:23 PM
Gripenfelter's Avatar
Pull off the fuse panel on the side and the bottom dash panel and look at all the relay fuses.
Old Jan 29, 2003 | 04:31 PM
95CamaroZ-28's Avatar
There is obviously some type of wiring problem. About all you can do is remove the bottom panel and take a look. Perhaps when they did the alarm install, somthing was under par but good enough to last 2 1/2 years before causing any issues.
Old Jan 29, 2003 | 05:26 PM
You are just going to have to search for it. The more smoke you can avoid, the better.
Old Jan 29, 2003 | 07:09 PM
FastrDamnit!'s Avatar
Lightbulb
Pretty much what everyone else has said.
I had a similar problem a year ago with smoke coming from the gear selector area. It ended up being a pinched wire that powered the center console bin light. Apparently, I would lean/rest my arm on the console too much when driving and somehow over time the wire got pinched.
I can't really see how you would have this same problem with something in the gage cluster area, but you never know.
Good Luck.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
