HELP!! Runs great, but won't start...
Old Jun 21, 2003 | 07:43 PM
70cst10's Avatar
Hi. I finally got the lt1 in my truck fired up today. The only problem is, it won't start without some starting fluid in the intake. It runs great after that. It idles perfect and roars like a beast with throttle. What could the problem be? It seems like the injectors don't turn on until after the motor starts. I don't know where to look for this..
Old Jun 21, 2003 | 07:53 PM
walt355's Avatar
lt1 wont start
I had the same problem with a '92 model chevy pick up(350c.i.). It would run ,at least decient after i got it started with a little shot of starting fluid. I checked every fuel aspect of the fuel system there was. Finally it threw a code and it was a $35.00 Throttle Position Sensor. It worked the best.
Old Jun 21, 2003 | 08:24 PM
Do you have the fuel system set up to prime the fuel rail like the stock LT1 has?
Old Jun 22, 2003 | 07:15 PM
scoobysnax83's Avatar
thats really the only thing that it could be. In laymens term. Does the fuel pump come on for a few seconds when you turn the key?
Old Jul 12, 2003 | 01:24 PM
70cst10's Avatar
Well, I figured out the problem a little while after I posted the question.. It turns out the direction the MAF is facing makes a big difference. It runs and starts like a champ now. I can feel the frame flexing when it shifts into second at WOT. That motor is a badass with a 3.73 rear. Thanks for the suggestions!
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
nophix
Nov 30, 2014 10:26 PM
Lederman1976
Nov 30, 2014 05:21 AM
