help-replaced h2o pump,no fire @ coil?
Old Apr 4, 2003 | 10:12 PM
hellostop's Avatar
94Z, I just replaced my water pump, and it turns over, but won't start. There is no fire off coil wire going to optispark. the coil is plugged in. Please dont suggest taking it back apart, my nuckles are trashed. Thanks!
Old Apr 4, 2003 | 10:24 PM
Make sure all connectors on the coil and coil module are plugged in securely and also check the coil fuse in the underhood fuse/relay panel.
Old Apr 4, 2003 | 11:02 PM
hellostop's Avatar
good guess, but the 10A fuse is ok, and there are 3 plugs-all seem connected, and a couple of grounds are bolted down.?
Old Apr 5, 2003 | 01:32 AM
delbuort's Avatar
Did you get the coil wet by any chance... before, or during, replacement? I had to replace my water pump once because the pressed hose was leaking and it was dripping onto the coil. Unfortunatly, it ruined the coil too.
I hope that's not what it is but its a thought. Good luck.
Jason
Old Apr 5, 2003 | 08:07 AM
You didn't unplug the opti by chance or got it real wet with coolant?
You can try this to help troubleshoot.
Old Apr 5, 2003 | 09:47 PM
hellostop's Avatar
Shoebox is the man!
I left the optispark unplugged, thanks a lot!
rrrrmmmm! rrrrrrrrrrrrrrmmmmmmmm!
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
ad356
Apr 11, 2015 11:12 PM
grabbem88
Mar 18, 2015 01:25 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
