Help Removing Crankshaft Balancer
Old May 26, 2005 | 08:04 PM
Randy L's Avatar
Got started on changing out the entire distributor on my '97 LT1...now I'm stuck. How do you remove the crankshaft balancer that sits in front of the Opti? Man, I tried turning those 3 bolts that hold the balancer on but they don't budge. Do I turn them counter-clockwise to loosen or are they reverse threads?
Old May 26, 2005 | 08:07 PM
FastZinTennessee's Avatar
Re: Help Removing Crankshaft Balancer
They are standard thread, turn counter clockwise to remove. Do you have a crank hub puller? You might put some WD40 on those bolts and let it soak for a few. Sometimes if they are on really tight I'd get a buddy to wedge a crowbar in the balancer and hold it in place while I used a breaker bar on the bolts. Not pretty but it worked........
Old May 26, 2005 | 08:11 PM
Randy L's Avatar
Yes, I just bought a puller. I've got the bolts soaking in Liquid Wrench right now. I guess I have to go work out at the gym! LOL Thanks!
Old May 28, 2005 | 06:23 AM
slopokrodrigez's Avatar
Use a long handled breaker bar and tap it with a hammer if need be. If you are just removing the opti and not the timing cover, you don't need to pull the hub and I recommend you don't pull it.
Old May 28, 2005 | 09:49 AM
phinger23's Avatar
mine came off nice an easy
probably because i just had my crankshaft replaced
Old May 28, 2005 | 11:06 AM
slimdawson's Avatar
Yeah, don't try to remove the hub. It sucks If the motor is turning instead of the bolts, put in 6th and the ebrake on.
HectorM52
Jul 30, 2017 11:46 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
BigWil
Mar 29, 2015 12:24 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
