Help Please - Runs Rough
Old Jul 15, 2010 | 04:21 PM
dnapowersports's Avatar
I have a 94 camaro lt1. Car runs ok cold but after driving it a few miles runs like crap. Misses like crazy on WOT. Idles like crap after that. During WOT I see a lot of black smoke out the tail I guess telling me its running rich? I just put in a walbro 255 fuel pump - no other mods to the car at all. I checked the fuel pressure - ok - around 40 psi. Vaccuum good - around the same. I tested the fuel regulator - ok. I unplugged the maf and map sensors and it runs even worse in open loop (I believe unplugging these does that). I replaced the coolant temperature sensor in the water pump as well. Any ideas? Could this be the optispark?
Old Jul 15, 2010 | 04:39 PM
CstIrnFst's Avatar
If I were in your situation the first thing I would do it scan it for codes. Have you done that yet?
Old Jul 15, 2010 | 06:18 PM
moparman's Avatar
Could need plugs and wires. When it's good and dark, start it up, open the hood, and see if you can spot any arcing around the plugs, wires, and coil.
Old Jul 15, 2010 | 06:40 PM
jethrobodean's Avatar
Sounds like heat screwing with the ICM or coil to me.
Old Jul 19, 2010 | 06:24 PM
carlson_z28's Avatar
check where your intake meets your TB. I know mine had a rip in the 90 degree elbow near the TB and caused my car to run like crap cause it was sucking way too much air. Dont know if that will help but just throwin out ideas to help you.
Old Jul 19, 2010 | 06:39 PM
Bails098's Avatar
when was the last time you did the opti and plugs, mine ran like crap when the opti went south.
Old Jul 19, 2010 | 07:38 PM
Peytons'z's Avatar
Have the o2 sensors ever been replaced?
Iamherefornow
Jan 26, 2015 04:57 PM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
