help please..misfing, not driving right..help
Old Nov 12, 2005 | 01:57 PM
white93lt1's Avatar
so i went to turn on my car this morning, and it started weird like a popping sound and a sputtering....then i warmed it up and i was feeling weird the wniter time so i put it in reverse and it is souning really bad...the only way to discrpe it other than u guys hearing it it was almost liike hestitaing, and choking...felt like somtihgn was holding it back...also the tranny was not shifting untill 3k rpms every gear....i dont know what it is i have a cam on a 108 LSA with a tune throuhg a burned chip...could this be becasue the chip?....it was driving fine last night and all of a sudden bam its messed up today....i really need some help on this one... maybe opti?...any iput please add
Old Nov 12, 2005 | 04:14 PM
white93lt1's Avatar
Re: help please..misfing, not driving right..help
ttt...anyone?..i needsome input?
Old Nov 13, 2005 | 07:41 AM
Guest47904's Avatar
Guest
When was the last time you got fuel? I just attended 2 nights of Advanced training and found out that filling stations are no longer required to filter the fuel coming out of the pumps!!!!!!!
Other than that, it's time to test fuel pressure. Fuel pumps seem to go out like a light bulb. Had my P-up since new in 99. Went to lunch one day fine. Went to leave, no fuel pump.
Relieve the fuel pressure at the schrader valve. While you do that, look for contaminates. After all the pressure is relieved, hook up a fuel pressure gage and see if you come up to proper pressure by turning KOEO and then off. Cycle the key on a few times and then check pressure.
Klypto
Mar 23, 2016 09:05 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
